KA-T EVO 8 OEM Turbo Kit
sudesh
Hello,
I am pretty new to this forum, I have a 97 S14, a friend of mine upgraded his entire turbo setup on his Lancer EVO 8. So I was thinking of maybe buying his stock parts from him and building a budget kit, how much work do you think it would require to get this idea to work? Has anyone ever attempted to do this? I've seen online you can get a JGS log un cut manifold and you can buy the EVO 8 turbo flange.
EVO 8 OEM Parts:turbo, internal wastegate (high boost setting) oxgyen sensor elbowFMIstockpipingfuel pumpBOV4 injectors (maybe can be used as additional injectors with a greddy rebic)oil feed line
thanksSudesh
sidewards
Car: 95' 240sx sr'd, 00' Sierra 1500, 94' cbr600 'fighter
If you could retain the twinscroll feature that would be so sweet. You wouldn't be able to do that with a log mani. Although you could use their flange and modify an after market evo mani to work w/ it, but that wouldn't be cheap.
