KA-T dies after getting into boost
Doya
Car: '95 240sx KA-T
Every time I get into boost and then let off of the gas, it dies. It runs just fine when I'm cruising though. A friend of mine said it could be that I'm running rich but I don't know. I just have a basic T3 top mount setup with a 6:1 FMU.
Razi
Car: Moo
Is your blow off valve recirculated?
Chris28
Car: 92 s13 KA-T
How much boost are you running? Do you have an AFR gauge? If so, what are your AFR's looking like in boost?
Chances are you're running slightly rich in boost, causing it to flood the engine when you go from boost to high vacuum. Try re-circulating your blow of valve like Razi said.
WDRacing
BOV issue. Disconnect the BOV or block it and see if the symptoms go away. Having a BOV vent previously metered air into the atmosphere creates a very rich condition on decel. This causes stumbling and stalling, very common btw.
Doya
Car: '95 240sx KA-T
I'll disconnect my BOV today and see what happens.
I'm only running 8psi and I don't have a AFR gauge so I have no idea what my AFR's are like lol.
biggie
A pic of the MAF and BOV setup would help as well.
rtrdpenguin
Car: 1989 Toyota Supra Turbo
Oh yeah, I forgot to mention the MAF thing. Sometimes having the MAF too close to the turbo inlet will cause some weird things to happen.
-Chris28
neverlift
recirc or go blow through and keep the sweet sounds :yesnod
Doya
Car: '95 240sx KA-T
Alright so I removed the BOV and the problem stopped lol. I'm going to put it back on and recirculate it back into the intake.
Quick question though, should my BOV release air every time I quickly let off the gas, or just after I've built up boost and let off the gas?
biggie
Just after boost is built, if there is no pressure there is nothing to release.
lexcrob
Car: I get a different ride faster than I could update this.
Would placing the bov aimed at maf/filter in close proximity work? That way you can run a bov/bypass without messing with piping.
Would running a bypass valve with a bleed valve rid this problem? My rb20det would just kind of surge when cruising if I didnt recir.?---it was a dsm oem unit same junk
^maybe putting a small hole after the maf would simulate the bleed valve and allow ecu to compensate when bov open.... Buddy mentioned this as a way to lean out a rich FLASH JWT etc. send outs. <--i was kinda doubting that would be a good idea --ignition timing *???
lexcrob
Can you elaborate on your set up walbro, t3?? vortech? --are you just readin plugs or wingin it hahaha
Lastly, from other threads i guess safc can be used to "tune out this problem. Dont know if it could work with fmu in place?
motoman399
Car: 98' wrecked (RHD coming soon) 240
biggie wrote:Just after boost is built, if there is no pressure there is nothing to release.
kind of.. in theory this is right ^^ but if you think about it, when you are accelerating at (lets say) 0-1 inches of vacuum. you suddenly let off the throttle and the throttle body closes. the turbo is going to continue pushing air as the turbine is still spinning and the blow off valve will release air. if you have a loud blow off valve, or a whistling one you can easily hear it.
