KA-T car wont rev up
mummbles20
Car: 1990 nissan 240sx
car idles great but when i try and rev up it just falls on its face. Its like im not getting any fuel to the motor. My AFRs are 16.8 to 17.6. I know thats lean so when i try to adjust fuel pressure from the regulator the higher i go the more lean it gets. I have 550cc injectors a Z32 maf and a chip from E-mance performance. I tryed to adjust the air but still the same. Anyone have any ideas. I would love the info thanks
480sx
Car: 1996 Pearl White 240sx
An engine thats not letting you rev over 2.5k RPMs is a red flag for a MAF issue.
Do you have a fuel pressure gage?
mummbles20
Yes i had the pressure at 38psi. And at 45psi and still nothing at all. Car idles great but no rev up at all not even over 1500rpm
480sx
Try bumping the fuel pressure up some more. It makes no sense at all that your AFR's would be higher with more fuel pressure. You can try it all the way to 60 without much worry about anything bad happenin.
So you have a wideband and its reading lean at all rpms?
Try running the car without a MAF attached.
mummbles20
Ok i will try it with the maf unpluged and the fuel pressure at about sixty. The AFRs are lean and i can not rev at all. Its like i said the idle is great but when i try to gas it there is nothing. It just drops rpms and stalls. I tryed to turn the air adjuster and nothing happins. When i start the car and it`s cold it runs rich like in the 11. As it warms up it goes to lean bad. Another question i have is where does the BOV go. or should go ?
Zippy69
Car: 1993 240sx coupe
Have you contacted Jason at E-mance? He is a really nice guy who will help you with any problems you have. Hit him up, I promise he'll try to help. I put my bov in the hot pipe after the turbo. If you have a chip from emance, was it tuned for 550's and the model maf you have?
CH552005
Car: 1993 240sx KAT super hicus
have u tried to see if its in time my car was off two teeth on the distributor and i advanced it two teeth and it is perfect
WDRacing
What else have you done to the car? Is the MAF wired right? Are all of the IC pipe couplings attached?
When the car is first started it will run rich when it's cold. It's supposed to, then it will lean out as it warms up.
When you say "air adjuster" do you mean the idle air control valve? If so you shouldn't be touching that at all unless your idle rpms are to high or to low.
What wideband do you have?
What is your entire setup.
neverlift
have you tried with the maf unhooked,triple check you maf wiring too. if its a z32 4 wure maf the one wire c IIRC goes to ground, NEES TO BE BARE METAL
BEST1TUNING.COM
Double check FPR feed and return line connections. make sure they are not reversed.
s13bassboat
Car: 1993 240sx coupe a.k.a bassboat
I just finished fixing my car with the same problem and what it was for me was the 5v reference wire was backing itself out of my throttle position sensor. check your tps sensor. for me it was cutting fuel at 2500 rpm and would'nt kick back in till i hit wide open throttle. i'd check your tps. good luck
mummbles20
I had no 5v referance at the computer for my mafs. So i jumped a wire from my distributor and it still did the samething. i got a new computer and E-Mance or Jason sent me another chip thats set up for the N62 mafs,550cc injectors, and the turbo set up. will check the 5v for the tps.
