and here is my zenki
liquid_cool wrote:take this advise to heart my sideways breathrin!....if your going to do it..go all the way..what i mean by that..is do it rite...biuld the lower end to handle a new turbo..the KA's weekness is the pistons and rods..shure some rods hang in there upto 300hp...but do you wana take the chance?..ney me...not only will you have a motor that can handle your current hp dreams..but be able to handle a bigger turbo later down the road...in my build...i usd K1 rods..good H-beam rod for the buck, can handle 600hp max...for pistons i used Supertech...inexpencive and high quality and comes with a free coating "Dry Lubricant"..i did however have my engine clearenced to finite tolerence's , i allso suggest upgrading to new valve springs and a mid cam to fully benifit the combination...as for the isis manifolds...im using the type 2 many, really a stout bottom mount for the buck..the turbo elbow left sumthing to be desired thou..the fit is to close to the transmission for my liking..and one nut wont go on due to the tubing clearence...hope this helps ya somewhat..good luck with your build man.
