Ka-t boost limit...
Structure240sx
from what everyone says the 370's will be good to 10psi but thats the limit so 8-9 u should be fine
SHiFT
offtopic, 98KA what color is your car. Do you ever go out to bithlow? I go to UCF and am wondering if I've seen you around.
Nismo1182
Car: Z06
SHiFT wrote:offtopic, 98KA what color is your car. Do you ever go out to bithlow? I go to UCF and am wondering if I've seen you around.
do you go out to the nissan meets on saturday?
98KA cars is the silver moss color.
WDRacing
There really isn't a boost/injector cc formula. If your ECU is tuned to run at 8-9 psi with 370cc injectors then you should be ok. I personally don't ever recommend turning up the boost without some sort of knock meter or putting it on the dyno, just so you can be sure.
But for an opinion only, I think it would be ok to run 8 psi with 370cc injectors in,
WD
