KA-T At Track or First Time....
240sxOwner
Car: 93 240sx
Well i finally broke the new clutch in and took it to the dragstrip in richmond yesterday. Track was prepped better than ive ever seen....here goes
1st run......The tires grabbed so well that my 3500 rpm launch dropped to 600rpm...lol ended up with a 14.8 @101.4 (2.66 60ft...lol)
2nd run...Feathered the clutch a bit more..spun second...14.4 @102.3 (2.43 60ft)
3rd run...Launched a little harder from 4500...spun a little in second.. [email protected] (2.10 60ft)
Wish i could have gotten a few more runs. I did some tuning earlier today and it is running quicker. These runs were completely untuned. Im installing my safc and aem wideband this week and i will be going back. Setup is revhard manifold, t4 on center turbo .58 turbine & .60 Compressor, JE pistons, apexi n1 dual exhaust, JE pistons, arp head studs. I was running on 7lbs
Let me know what you think...i know the 60' could be better but i was improving...lol
PencilShavings
Car: '91 240 hatch
looks good, you dropped your 60ft time by .5 seconds in 3 runs, id say youre headed the right direction
just wondering..where does that turbo start spooling, and where do you see full boost?
Nismo_Freak
Car: 89 Nissan 240SX
Your trap speed is not good IMO.
KATwo40
Car: 1993 240sx KA-T
Nismo_Freak wrote:Your trap speed is not good IMO.
Small turbine housing?
Seems like a .63 A/R would be a min.
Nismo_Freak
It's a .58 T4 housing, it's big enough if not oversized for that engine.
At 7 PSI he should be making 250 - 260whp on that setup.
KATwo40
Nismo_Freak wrote:It's a .58 T4 housing, it's big enough if not oversized for that engine.
Ahhh, overlooked the T4...
Maybe his flux capacitor is broken?
240sxOwner
Car: 93 240sx
starts spooling about 3K and i hit max around 5K or so....
Possible boost leak in the intercooler piping? I did retard the timing back a bit more today and it is a little peppier and more responsive..
I though a .58 was a pretty good size for our 2.4...I have some video but i don't know how to host it or anything...
KATwo40
Uhhhh...I think you mean ADVANCED the timing? Retarding moves it closer to TDC...less "peppy"
240sxOwner
Car: 93 240sx
yes...i advanced it....sorry bout that
NateDogg
Once the turbo starts creating positive pressure it should only take a few hundred hundred rpm to reach 7psi. You should make full boost by 3500rpm at the most.
I bet you have a leak somewhere..Have you done a vacuum leak test?
240sxOwner
Car: 93 240sx
no i haven't done a leak test...what is the easiest way to do it? Please enlighten me as i am a turbo newb...lol
mirra32
sweet let us know new track times when you get her tuned...PROPS....what gap do you have....and where is your timming set....any problems with your set up so far....any tips.....
