But it's going to take more than "3psi over base" fuel pressure.bruinbear714 wrote:You can do it with a FPR and a fuel pump...
There is no mystery.uncle_louie83 wrote:we know that nismo freak...were just trying to solve this mystery here...ive seen it with my own eyes on the SOHC...for example import ants car...its impressive for the setup. I guess i can see how it works but at the same time its confusing. maybe the maf reads the more air coming in and the ecu compensates with more fuel...because he isnt maxing out the maf yet..hasnt reached 250whp. he does have the equipment to do a more reliable setup but that isnt going on until next season. I enjoy talking with aaron about ideas and new things about the 240 world. the guy is smart
all im trying to figure out is...can this be done on the ka and if so how many psi ?
i know a guy locally who has an s14 with a small t4 and he is pushing only 7psi...only upgrade he has is a FMU...and thats it. He has been running this setup for 4 years now. the whole car is stock...suspension and all...just an old guy named bill who works for a local motorsports shop and that car is impressive too....its truly awesome how the stock fuel/ecu can work with boost here.
WDracing has shown his stock fuel pump is good for 14psi....well can the stock s13 fuel pump do this too....or what is the limit for the stock fuel pump...
im trying to collect data here...so if you know the stock fuel pump limit? please chime in if anyone does
while it is a cheap part to buy, he was just curious if anyone KNEW of the capacity of the fuel pump. he wasnt asking Florida to test it out to its limit. the PURPOSE of budget building is getting the job done for the lowest cost. Lewis is just trying to discover if there is an option to use what he has to make a setup that flows better than something he's going to have to spend 100$ on. I'm not his lawyer/spokesperson but I do see where he's coming from. while it may be evident to you or I that it might not be a smart choice, that's the purpose of this thread isn't it?Nismo_Freak wrote:
You are talking about simplistic modifications that are cheap and readily available. To me there is absolutely ZERO reason why you should even consider running a stock fuel system ghettorigged to barely keep the engine alive.
You are inviting failure.
Brian could have blown his engine trying to find out about the fuel pump's capacity. All for the sake of a $100 shipped part.
Do you want to constantly replace motors, and shell out money just for the sake of knowing when the 100+k mile stock parts will give out? If so you are defeating the purpose of budget building anyways.
Word. Can't press that enough. I bought my car with crappy parts already on them. This winter the car goes into storage and I am rebuilding my entire motor with forged everything and getting a STRONG manifold, great turbo, redoing all my piping to be solid, getting all guages, and fuel management, and upgrading the injectors.Nismo_Freak wrote:Do it right the first time
