briguy »
https://forums.nicoclub.com/briguy-u39060.html
Wed Jun 13, 2007 11:55 am
Ok,I just finshed my ka turbo project in my 1995 240.I put in a new nissan crank,Clevite bearings and new stock rods and pistons,I also put in s-13 cams.My turbo setup is a t25 turbo(off a sr20) SSac bottom mout manifold, 3 inch downpipe and 2 1/2 exhaust back to a 5Zigen muffler,I am using a Old school hks super blow off valve,Front mount intercooler,Still using the stock maf sensor and injectors for now I have 370 injectors,and a infiniti maf and a High volume fuel pump A chipped ecu tuned for the turbo injectors etc., that still needs put in.I wanted to leave the maf and injectors stock until I break the motor in.Now heres the problem when I let off the gas or go to downshift it wants to backfire sometimes,I havent boosted past 5 psi yet,and the motor has great oil pressure and runs so good.Also I am not running a safc or anything else,If you guys could give me advice on how I can improve my setup or just have any advice that would be great,Also is anyone running something similar and know how much horsepower this setup puts out!!! thanks brian
