KA-T 638 RWHP 599 TQ
IvanAtSPRacing
Car: I make cars fast
Click HERE
TheOne
Car: 93 240sx FB
sooo.....Mucho torque....so whats the twins doin for traction?
specs, i really don't know much about what yer building for them.
and somebody forgot the video:(
virus77
Car: 95 S14, 71 240z, 97 e320
I said it before and Ill say it again, good stuff.
ILikeMy240sx
Car: SR Power
im speechless once again... Oh yea a video like last time would be great!
DriftingisLame
Car: '91 240sx coupe, rb20det
Wow!
oh, and where can we get those anti-SR stickers?!
hannibal
Car: Red Line to Glenmont
Amazing numbers as always!
I wish I had money to burn on a dyno queen like that. What the hell do these guys do for a living? (I guess its easier if you 'share' a car with your brother...)
klattr1
Car: GT42R powered S14/KA
IWannaS15 wrote:Amazing numbers as always!
dont we all. wait till you see it run at track again. its already ran 11.7 with ALOT less power. hopefully the drivetrain will survive to finish the pass.
ILikeMy240sx
Car: SR Power
Correct me if Im wrong but I think the twins dont have to pay much if anything at all because they loaned the car to Ivan as a research car sooo.... lucky them
hannibal
In that case, let me find a $300 POS beater for Ivan to work on
crzycav86
Car: 93 Nissan 240SX KAT
Wow. I guess that goes to show what lots of boost, and a good aem ems tune will give you. Obviously, the intake is not up to par with the rest of the system.
Congrats on a new record... again.
klattr1
nr2134
Their setup would be a bit more money than others available for the KA, but look what you get. And I honestly dont think its all that much. The return is greater than the investment. The sad part is ........Ivan is not even close to being done with it.
240SicknessX
Car: 96 240 SE
nr2134 wrote:The sad part is ........Ivan is not even close to being done with it.
lol, there is nothing sad about that. maybe subsitute ironic?
as always good numbers...... also could you keep a running list of mods that are making these numbers possible? and at what boost level. ~33-34?
nr2134
The mod list has not changed since the last dyno run except for different cams and I think his MBC tops out @ 30psi.
240SicknessX
Car: 96 240 SE
well then, unless those cam specs are top secret. lets see them.
i was unaware of the different cams. so no more 33,34 psi. a few lbs more with cams will yeild kick *** those numbers.
deezlins
Car: 95 240SX SE
damn, thats awesome. keep goin, the sky's the limit
Jookmasta
speechless on the power output on a mustang dyno.........
SSS
God damn...great work!
Red-KAT
Car: 1995 240sx-se ka24det
Jookmasta wrote:speechless on the power output on a mustang dyno.........
Thats what I say... OMG!
Put him on the same dyno we all use and see what happens...
DriftFasterThanGrip
Oh hell yes!!!!!! Thats a lot of tourqe. I've noticed that the better tuners out there always pull higher tourqe numbers than usual and this would be the case with Ivan's results.
DRIFTEADOR
is the link still working for everyone else? congrats on the numbers. thats the record high for a ka-t, right?
Fergus
Car: '01 C5 Coupe
hasn't worked for me since about 9:30 est
Craving4Boost
Car: 91 240sx fastback
*bows* oh hail ivan
klattr1
the site is back up now.
2FourTee
Car: 96 240sx - Supercharged ka24de
Ummmmm...... WOW!?!
HolyShiznit
Car: Working on my car
Ivan for the WIN!
IvanAtSPRacing
Current mods are:PK turbo kit with PK GT-35 turbo (non bb, E cover, T3 5 bolt, .63 A/R)PK intercooler rated to 400 HP, 2.25" hot side 2.5 cold sidePK fuel system with 95lb injector / ballast resistor upgrade, second in tank pump upgrade.AEM EMS with speed density conversion kit (no MAF)PK turbo motor (Arais pistons, Clevite bearings, Crower rods, Cometic gasket, ARP head and main studs [heads upgraded to 11mm] Crower valve springs and retainers, and Crower V2 cams)
The run was made with VP C16 racing fuel at slightly over 30 lbs of boost (I dont know the amount because the boost gauge and MAP sensor max out there)
Something is holding back the power for the last 2000 rpms. Lower boost runs showed a signifigant increas in power with the new Crower V2 cams that wasnt there on higher boost pulls. When I get rid of the cork in the system, this motor is going to come alive and probably shock some people
I need to get some dyno sheets scanned and I will be posting about the Crower V2 cam test and the awesome results we got.
hysteria
Car: s13 kat, sv650s, and other projects
ok well that's just rediculous.
Jookmasta
u know thats simply amazing to see the power output for that setup still has a "cork" in it............boy i wish that was my car. i also just noticed that phat-kat will need to produce a better intercooler kit if its rated to 400whp and yall are producing those numbers. but then again, how many 600 whp ka-t's really run the streets or are dd's? nonetheless, more info on those crower cams please...........
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
holy crap thats incredible, awesome! vid of dyno run!!!
-Dan
