KA Swap
e2amracer
Car: Initial D, Drums, Trance and road racing
Is there much modification for a 95+ KADE swap into a 90 240sx than going with a earlier one? :help
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
why is this KAT related?
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
Shouldn't be much problem. The motor drops in if that's what you mean.I've seen problems with trying to use a manual ECU for an auto car. I don't know if you are swapping to a car with a different transmission, but there ya go. Other than that you only have easily modified things to hook up. Vacuum lines, Radiator hose, PS lines(if you want it), all not too bad at all.
Some of the obd2 sensors might not like you though if you don't have a 95+ ecu...
