No luck in the ka forum so thought i would try here since the engine going in my 720 is from a 240. Here is what I have so far:
roasted one ecu and wiring harness (fuel pump was running when truck was off and all sorts of weird stuff)
Replaced ecu and harness wired it the same and fuel pump runs as it should now (on for a bit until pressure is built)
Engine cranks
no fuel
no spark
i did put in a high pressure pump of course since ditching the carbed engine
ecu is throwing codes 11 (CAS) and 41 (intake temp sensor wasn't installed i hooked it back up)
checked grounds at distributer (forgot that one oops!), coil pack, and pretty much any grounds that I added. I grounded the engine, and the relays as required think of any that i missed? Here is the schematic i followed.
http://community.ratsun.net/topic/537-h ... 4b13e893d2
There are several wires that pass through the ecu connector and are not hooked up to any pins not too sure what these are for were not in the schematic to be used so i just capped them.
What do you think I should try next? any opinions are appreciated this is my first project like this so even if it's stupid simple still suggest it!
Thanks
Nathyne
