enerj »
Sat Dec 05, 2009 3:33 pm
Thanks for the response Razi. I have two ECUs from my days of throwing money at this beast. I mostly use the first one, although I have plugged in the second to check if the ECU was a problem.
First ECU3C - A18-B92 G21 95 240SX N M U OBD2 S14-KA24DE 23710-70F01
Second ECUCA - A18-E27 G49 96 240SX N M U OBD2 S14-KA24DE 23710-?????
These results were returned from the JWT list. The only thing I can think off is that my car is a 95' OBD1 S14. Both ECUs state OBD2. Could this be an issue?
Going back to the IACV, the pages covering it are from EC 110 - 114 in the FSM. One of the diagnostic procedures calls for me to idle the car for 30 secs and do some things, obviously this isn't possible.
However I will go through the other portions of the instructions to see if I can find anything. Although the IACV may be causing some problems, I can't imagine that they can be this severe, can they? Wouldn't it have to be a terribly big leak through the IACV to have the car not even able to idle?
I still think I have an issue with my fuel/ignition but I will get a friend to help me with that and make sure all injectors and plugs are firing.
Lastly, I bought a cap and rotor from pepboys. The strange thing is, when i just play around with the cap and rotor without the actual dizzy, I can see that the middle point in the cap can't touch the flat metal part on the rotor that feeds the voltage to the plugs. The plastic part on the rotor is too tall and hits the plastic of the cap before the springy middle contact in the cap can touch the rotor. This isn't correct, right?
Thanks again!
