ukrainekid »
https://forums.nicoclub.com/ukrainekid-u131845.html
Sun Jun 06, 2010 3:44 pm
Ok i have a 93' S13 with a KA24DE. I am having an electrical issue I THINK. I am gonna run you through what i did and maybe someone might catch where i may have caused a problem.
One of my injectors went bad(i have sr20 injectors) so i was temporarily changing the bad one out with one of my old ka injectors. I had disconnected the Fuel pump fuse and also i disconnect the line to the fuel filter to relieve pressue since i dont know any other way. Everything went smooth until i went to crank the motor. When i turned the key and put the clutch in to start, as i attempted to start the motor made like a click and thats it. It didnt attempt to start at all.
Then after that my alarm start acting retarted and my lights or nothing electrical except for the digital clock on the cluster. it was as if there was no power. So i took my battery to get it checked and it was perfect.
what i find strange is that when i disconnect the negative negative on the battery and put it back on, the electrical components and alarm came back to normal. Well not everytime anyways. But as soon as i tried to crank again same thing. One weird click and back to where i started. I checked fuses and everything was fine unless there is something i dont know. And to add my car runs like new.
I am assuming its electrical because of the symptoms but i am not a mechanic so i only know so much.
Please help lol...... Thanks
