MJDalton »
https://forums.nicoclub.com/mjdalton-u53395.html
Fri Nov 02, 2007 2:17 pm
Here look this over maybe it will help :
just general specs,
first the gases"HC" is your hydro carbons. organic compound that contains carbon and hydrogen"CO" carbon monoxide. incomplete combustion of hydrocarbon(fuel) and oxygen. Colorless, and odorless"NOx" nitrogen oxides, nitrogen and oxygen produced at higher combustion temperatures"CO2" carbon dioxide colorless, odorless, heavier than air"O2" oxygen
a exhaust gas analyze or the emissions test should give you your read out for the gases at what your truck is currently producing
with good combustionCO2 should be about 14-16%. increases with the efficiency of combustionCO and O2 should be low and equalHC Low level is bestNOx should be just lower than max at your are fuel ratio of 14.7:1
High CO= Rich condition, CO is partially burned fuelCauses-High fuel pressure-Leaky injectors-faulty temp sensor-thermostat stuck open-clogged air filter-sticking choke-high float level-leaking accelerator pump or power valve-charcoal canister full, fuel to topped off, faulty purge solenoid-Fuel in the crankcase
low CO/high O2 =Lean condition-to little fuel-to much air-low fuel pressure-plugged fuel filter-bad fuel pump-plugged injectors-vacuum leaks-low float level;-plugged or wrong jets
High HC= incomplete combustion-bad ignition, coil, plugs, wires, cap, rotor-over advanced timing-low compression-stuck EGR
Low O2-Rich condition. still burnable fuel mixture
High NOx-combustion temps over 2,000*'s-thermostatic air cleaner stuck closed-higher compression-to far advanced timing-low oil level-cooling problems, getting to hot. thermostats', temp sensor, radiator......-to low of octane- Faulty EGR-Vacuum leak-low fuel pressure-wrong heat range of spark plug-cat converter junk
CO2- before engine warm up, when still in closed loop, should be 10-13%after warm up, should be 14-16%if it doesn't increase catalytic converter is not functioning properlyCO2 below 10% indicates extremely dirty exhaust and/or cat converter isn't operating
High O2 +high CO + high HC=misfire do to over rich mixturehigh O2 +low CO + high HC= lean misfireHigh O2 +Normal CO +high HC= miss do to mechanical or ignition problemsHigh O2 + normal CO + normal HC= O2 getting into exhaust via air pump, or exhaust leak
if HC goes up, O2 should go upIf HC goes down, O2 should go down
if CO goes down, O2 should goes upIf CO goes up, O2 should go down
CO2 should be highest at the engines most efficient spotC02 goes down if anything else moves.
Good Luck Mike
