Lopin18 »
https://forums.nicoclub.com/lopin18-u58480.html
Tue Aug 12, 2008 2:47 am
the all harnesses in the engine bay, meaning the ones from the dashboard, to the engine all those, were checked and properly enclosed, still ill be checking for damage and contacts...
by the feed ruber line, i mean the rubber line that comes from the fuel tank and connects to the fuel filter, when i last went into pits i didnt smell fuel, but after i started the engine again i smelled it and the hose was totally cracked, changed that, but that isnt my problem cause i never smelled fuel in any other runs...
Ive been reading and i noticed some plp with my problem say that these guys can be the problem:
- Crankshaft position sensor (the module behind the distribuitor), they say that it heats up and shuts down, thus cutting all spark in that moment and shutting the car.
- Coolant Temp Sensor, suposedly if this thing is bad, when it reaches operational temp the ecu shuts down the car if its damaged, but... ive driven for LONG hours and car doesnt shut down, just when im drifting....
havent had time to check the car, but tomorrow ill be on it, ill recheck all wiring for Contact damage etc...
To test it ill be doing Donuts!!!, that will recreate the problem, since ill be doing a lot of chassis flex, lots of load, lots of heat, soooo ill troubleshoot on the fly.
BTW!, Santo domingo, Dominican Republic :P i put FL in there since my shipping address is there
