liquid_cool »
https://forums.nicoclub.com/liquid-cool-u100587.html
Sat Aug 29, 2009 5:45 am
is it runnin lean at idle? or when you go WOT?..if its the latter..then you can fix it easyer..the issue might be your fuel pump at higher rpm ranges ...you can ither get a larger flow pump and replace what ya have..or add a helper pump inline to help maintain flow...if your issue is at idle to wide open throttle..then you have a few things it could be...pump,regulator,injectors and vacume...you dont want to run lean..ever...till you can track down the issue..you need to add some Octane boost in your fuel tank to prevent detonation and engine damage...hope this puts ya on the rite track man..keep us posted on what ya find.
