deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sat Nov 04, 2006 2:31 pm
Here is some specs, from memory (vernier not mic, so approximate)
KA, approximate
B.E width = .975"Journal dia. = 1.96"Pin dia. = .827" (full float bushed rod, 21mm pin)(non-truck)
Z24 (alternate, same length and build strength compared to KA) appox.
B.E width = 1.050"Journal dia. = 1.96"Pin dia. = .826 (press fit 21mm pin)
The big and small end both have the same width on each rod, respectively. The z24 rod has approx. .080" wider journal, otherwise similar build (strong rod).
Both rods should be well suited for some narrowing to fit a custom application (within reason). Be aware these forgings are extremely hard, try to stay away from honing as much as possible, lots of time involved for the machinist (like refitting piston pin to alternate diameter).
If you want to work with a larger piston pin diameter, try go with the 240sx/STANZA/ALTIMA rod and not a truck or z24 version. The bronze pin bushing can be honed out and it is easier to hone the rest or insert an alternate bushing to fit.
IIRC the I.D. with the pin bushing removed is around .940" , but that might be some toyota spec stuck in my mind, not sure.
I do this stuff a lot too, sounds like a cool project. Not to familiar with your application, but you may be able to work in a slight offset grind when getting the rods fit and stroke/de-stroke, just a bit.
