deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Nov 23, 2004 8:54 pm
Regardless of components, due to the nature of the ka 2.4l rotating assembly you will see a very damaging harmonic from 8-9?krpm. In the common divisions where the ka is raced and allowed to be built competetive you will see a lot of what they have done. As for bottom end the crankshafts are 100% custom units retaining the oem dimensions, usually 4340 steel billet std race material. They will lengthen the rod 5-7mm and use a high quality forged unit. This gives the KA just a tad more headroom for operation at higher rpm due to its effect on piston acceleration. At operating ranges of over 7500 when stress is at its highest, the drivers side engine mount is a common place of failure (block crack). Most race vehicles run solid engine mounts, so the common A/C location on the block is what a lot use and i think is best as well (instead of std engine mount location). Block failure in other places is common at this barrier as well, large stress cracking due to harmonic.
The ka24de nismo/artschmidtt race trucks have basically identical modifications done to the bottom end. Nismo carrillo connection rods designed for nasport, and a race steel crankshaft. The cylinder head uses unknown valves and springs, but retains the stock cam base circle. Because of this and the fact that such large lift and duration cams are necessary (they are direct, biggest you can get as far as lobes) the buckets and shims have been enlarged. This is necessary so that the camshaft lobe does not fall off the side of the shim.
You can go ask any famous old ka builder, if you dont take my word, they will tell you the same. Try contacting Don Nimi up at pdm-racing.com . Most of the other guys have died or moved on, some still working for nissan.
