moso »
https://forums.nicoclub.com/moso-u137641.html
Sun Jun 26, 2011 8:30 am
if you plan on running it n/a and then boosting later you will find the 9.1 wont need any changes to run it from the stock ecu/injectors. if you change the compression and try to run it n/a with the stock setup it will have too much timing and not enough fuel. keep the stockish compression and save the tuning for when you go PSSHHHH!
