Ka Question??? Help!!
tx_widebody
Car: nissan 240
Okay here is my situation, i just bought a 90 240 that has a ka24de motor in it. I bought it for a whopping 50 bucks because he said it had a blown motor which was still a great deal i think. But anyways, i checked the motor out and it had two spark plug wires blown out, not to mention it had some cheap wires, so i pulled the wires out and the plugs, and the plugs looked ok.Next i did a dry compression check and i got 0 across all the cylinders, but then i put some oil in and did the check again and got somewhere around 125 on all cylinders. So i got new wires and plugs and tried to crank it, but it just cranks and cranks and finally after a while of just cranking it finally starts! The car runs good but when i shut it of and leave it for a while it takes forever for it to start up again. So does anyone have any ideas on why it takes forever to start up?? Wat should i do to get this thing running right???
jserrano
Car: 1994 Nissan Altima SE
It still seems to me like ignition problems. I would check the ignition timing and for oil in the distributor's camshaft sensor.
tx_widebody
Car: nissan 240
humm i wil have to check thanks
kouki_monstor
Car: '92 180sx
wow haha. u lucked out man. I dont think u could buy a car for 50 bucks anywhere, let alone a 240sx with a RUNNING ka24de. Some people just dont know anything about their cars...
I got my car for 300 with a ka24e with a blown headgasket, and i thought that i got a good deal. U just totally beat me on that hahah. Good luck with the car!!
tx_widebody
Car: nissan 240
Thanks, the guy i bought it from thought it had a blown head gasket, but i got it running it still just takes forever to start up.
tx_widebody
Car: nissan 240
bump 4 help
kouki_monstor
Car: '92 180sx
the first thing u should do is reset your timing and have a look at that distributor. then if that doens't help then, since this is an ignition problem, check all the ignition components such as alternator, starter, solenoid, etc...
