supra brit »
https://forums.nicoclub.com/supra-brit-u17265.html
Thu Apr 20, 2006 6:54 am
Yeah but you can great a crapload of power out of a single cam too. There's pros and cons too both...
DE = 155hpE - 140hpThe E is a PITA to work on as far as timing chain and timing in general b/c the oil pump runs off the distributor. The DE is easier to work on.
With the E you only have one cam to worry about (cheaper upgrade) and for the DE look to spend quite a bit on 2 cams (if you go that route anyways).
E's are cheap as hell (sometimes free) and easy to find parts for...DE's are a little more expensive, especially depending on how new they are.
If you have an 89 or 90, you'll have to do a little more work to swap the DE in than the E (obviously)...so just depends on what you're looking to spend and how much work you want to too, along with long-term plans.
