DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Jan 14, 2007 3:13 pm
i fairly certain i know what this is.
you already told us you can ehar a HUGE vac leak, thats what you eman by the "turbo noise"
however, this is so very common, and i fought with it for around an hour yesterday:
i'm guessing you have a vak leak around the big rubber o rings that seal the injectors to the manifold. they are hard as hell to seat sometimes.
if you can get someone to help you to keep the car idling, stand outside it in the bay, and use a length of hose to lsiten in specific areas for leaks. you'll know when you find it.
however, im fairly certain thats where you leak is, i went through the exact same stuff yesterday getting my custom manifold running.
so go check that out and lemme know, if thats not it, using the hsoe will help you.
