okay I did a little search for you.
Here is couple of threads I found talking about RB20DET wiring.
zerothread?id=225172http://forums.nicoc ... ?id=191744
This last one has couple of picx in it.By the way it's hard to get picx for wiring. Most people dont take pics when their doing the wiring (including me).
And S14 wiring is different from S13, you won't have same plugs and wire color wont match.
Try this site to get your wiring for your S14.
http://www.240edge.com/manuals/240sx-1995.html
Basically you will have to go back and forth through wiring diagrams, and compare S13 to S14 and try to figure out your wiring.
All the wires should be in engine compartment, dont know about S14, but S13 you have to run extra wire from inside car to under hood for fuel pump relay.
By the way what car is it, I know it's a S14, year, and what trans (auto/manual)
I will check back Sunday, I'll what I can do. Maybe I'll make some sort of wiring diagram and explanation to go along with it. But I will have to find my print-out and notes.
You only need couple of wires to run the motor, others are like gauge crap/ and revers lights/neutral switch/5th gear.
Just get the thick ones figured out for now. out of like 14 wires you only need to wire in like 8 and fuel pump relay.
later.
