after all that i don't think burping will help sound like a head gasket to me. i mean lets face it if you replace the water pump and then run it some time between one of those process of the turning off you vehicle and letting it cool down to do the the next thing; it should have burped out. unless you did all that at once. and putting the thermostat backward is a possibility and you shouldn't be insulted by that. "IF YOU NEVER MADE A MISTAKE YOU NEVER FIXED ANYTHING." that is how WE ALL learned.DubsSuck wrote:im stumped i've replaced everything. radiator water pump electric fanhosesthermostatthermostat housing
i have no clue
headgasket is band spankin new, and i think i should bleed my block befor i go tearing everything appart... again. and yes i did pretty much do it all at once. i also made sure the thermostat wasn't in backwards..Bongpain wrote:after all that i don't think burping will help sound like a head gasket to me. i mean lets face it if you replace the water pump and then run it some time between one of those process of the turning off you vehicle and letting it cool down to do the the next thing; it should have burped out. unless you did all that at once. and putting the thermostat backward is a possibility and you shouldn't be insulted by that. "IF YOU NEVER MADE A MISTAKE YOU NEVER FIXED ANYTHING." that is how WE ALL learned.
i was looking to see if the electric fan was kicking on but it wasn't, and the clutch fan is always moving. i should probably see if the electric fan relay is working. does anyone know which one that is?Wc240 wrote:are you sure your fans are working properly? and do you have just one or two? if its one, make sure its big enough to coveer the majority of your radiator and is strong enough to move a good amount of air. at what temp do you have the fans kicking on?
