Mine did that once upon a time. I changed the thermastat and it went well for about a month or so. The problem then resurfaced. I did a complete flush, changed the thermostat again, and ran a sealer just in case. Again problem solved . . . for about a month. Bubbling and overheating returned each time. Come to find out I had a warped head. Had the head rebuilt only to blow the gasket completely two weeks later. The #4 cylinder was steam cleaned to look brand new from this. Ended up replacing the motor so be careful since your gauge went all the way to the top. Don't remember the exact degrees but it's hotter than what your engine is supposed to ever run. Keep a close eye on it especially no that it's almost summer time.hondah8n wrote:it was the thermostat. thank God it was only that
