Funny, I kind of assumed that the rolling smiley indicated that he was being sarcastic.Daotoad225 wrote:
WHP goal = 300 - 400
Thank you for the info.DjPantsSpecR wrote:go to nissan and get the early model "88" (build year) SOHC pistons, you can even order them from nissan 1mm over, with rings i think its gonna cot you something like 350, i cant remember from when i was quoted
but you'll need to get those pistons flycut for the valves because the compression will be about 11.8:1. Now you could use the 89 build year or older style SOHC pistons and with the 1mm overbore you would still be sitting pretty at 11.2:1, and you wont need to get the pistons flycut.
now you are a little closer to that 2.5 liter
fasteners, no one said anything about fasteners, chances are you are gonna want to rev the piss outta this thing to make any high end, adn for that get ARP everything you can get, mains, rods, and head. also replace the bearings while you are doing all this ****
and then look at getting an entirely custom intake manifold, i am seeing these more and more these days or you could shell outa 600 bones for the excessive motorsports one.
NA is expensive, but it cant be beat for a fun daily driver, i gotta run to class or else i would stay here and rap, but ill be back once i fix my computer at home
haha c'mon man don't scare him away............nvrplzd240 wrote:dont mean to be a d*** or anything...but found this and thought of this thread
call me a noob if you want, ive never heard of a crank scraper? 330cc's will add 40 'donkeys' i assume you are reffering to horses. I intend to tune the ecu myself or if it looks too difficult i will get a tuned ecu, or get a safcBigvinnie wrote:If you are doing all that work you might as well get a Crank Scraper and windage tray. Might as well do a Knife edge (to the crank) through IPP for $250 as well. Get better balanced harmonics, and a bit more HP with a little more higher rev with those added. Keeps your oil cooler too.If you are going to run that 10.6:1 CR you can upgrade your injection rate to 330CC's and pull a cool 40donkeys right there.Also add a tuned ecu to the list. Using the higher CR pistons on a stock tune, and injectors will actually not show very high numbers in HP. The engine will run too lean and the knock sensor will automatically retard your timing to prevent detonation.
Obviously some one ripped you on the ecu tune...Just for future reference a stock FJ24E had a compression of 11.1:1 that engine made 238hp at the flywheel, mind you that this is a stock engine from Nissan that was manufactured in only Europe and Japan for the Silvia, (it wasn't even modded yet).It is a less effecient engine than the KA24de (which is much more modern), since the KA uses a pentroof dome head over the FJ, FJ used a hemispherical head design. This means that the flame front on the KA is stronger. Both the KA and FJ share pretty close similarities to the rod stroke ratio, this means in comparison to (boreXstroke) the 2 engines are very similar in producing close to the same power output.KA uses a 89mm bore FJ uses a 92mm bore so you can see where the slight differences are in it's stroke. FJ also used a fully counterweighed crank, unlike the KA, FJ was rev happy past 8000RPM.Number one killer of the DE's is the long runners to the mani, and it makes the engine anemic at higher RPM, manifold and header modification will literally multiply it's power output.SMoKeM240 wrote:you wont even get 200whp with that.. i did 10.5:1 comp bored .40 pistons, light weight crank pully, knifed edged crank, ported head and 3angle, short ram intake, header with full exhaust, tuned ecu, blah and it was still slow.. good luck
There is no FJ24E.The FJ24 was rated at 238BHP, was carb'd with 11:1 CR, and was never made into production. It was for the 240RS Group B rally car. Later put out 278BHP.Bigvinnie wrote:Just for future reference a stock FJ24E had a compression of 11.1:1 that engine made 210hp at the flywheel, mind you that this is a stock engine from Nissan that was manufactured in only Europe and Japan for the skyline, (it wasn't even modded yet).
Yep my mistake you are correct sir it is FJ24 (not the FJ24E). Nissan made this as a rally series engine. Designed for the 240RS(Silvia) platform (not skyline) Although early production skylines (DR30 RS-turbo) used the FJ20et,(DR30 RS) used the FJ20e.You are also correct with the hp rating according to this article.http://www.fastroadandtrack.co...713bbSeishuku wrote:There is no FJ24E.The FJ24 was rated at 238BHP, was carb'd with 11:1 CR, and was never made into production. It was for the 240RS Group B rally car. Later put out 278BHP.
The FJ20E was rated at 150BHP, ran 9:1 or 9.5:1 compression.
Yep. The engine itself basically came in kit form, race only direct from nissan. Usually these were bought 2 or 3 at a time with spare parts of course.Seishuku wrote:There is no FJ24E.The FJ24 was rated at 238BHP, was carb'd with 11:1 CR, and was never made into production. It was for the 240RS Group B rally car. Later put out 278BHP.
True too that, I went searching for an FJ24 hoping to find one for a 510 project. There was one in U.K that could of been delivered to me for $18000.00 (yeah right I can't afford that!) . This engine is extremely rare, and I didn't know how rare it really was until I saw the price tag. This is Datsun/Nissans racing breed engine, this engine is well engineered, and is still admired by many datsun owners. For beeing carburated it outperforms todays Honda F20/22 MPI engine. Outperforms on all levels NA 4bangers with peek torque at about 6000RPM, and peak HP at almost 8000RPM, this engine is a monster high rev 2.4litre.I only brought about the point that if you aren't making over 200WHP on an NA KA with high compression something is seriously wrong. Many of the engineering that went into the KA is direct geometry from the L/Z/FJ if you compare the bottom ends and rod stroke ratios to these engines they are very comparative. Infact KA is nothing more but a re-engineered and up to date l/z engine. With todays MPI and proper ecu tuning the KA should make pretty good numbers, and having a much larger stroke than the FJ24 should produce that peak power much earlier in the power band somewhere around 5600~6000RPM, if built right (that also means a completely redesigned manifold for the DE's). I'm not saying it is an FJ that would make upto 170BHP out of the box, but a properly built NA KA can make decent numbers. If most of these NA KA guy's followed the tricks of these oldschool datsun enthusiasts we could be on the right path to some serious NA KA engine building. But then again no one here takes NA KA seriously and would rather boost.deviousKA wrote:There is maybe 3 or 4 real fj24's in the states, tops. Maybe 15 or so left worldwide.
OOPs didn't see your question earlier. Well I'll be nice this time, but you should search. I've listed these parts myself.A crank scraper breaks the windage oil cloud and oil that disturbs harmonics to the crank. As revolutions increase oil heats up and causes a cloud to form, also due to oil frothing and flinging through the bottom half of the engine. A scraper literally does what it says and scraps oil off the crank and drops it into the oil pan before it is sprayed and frothed through out the engine. It prevent's engine starvation, drops engine oil temp, and increases rev and hp. This is infact a great piece to utilize for a wet sump system, you should also get the windage tray keeps oil from blowing upward or out of the tray. The 2 items are under $110.http://www.crank-scrapers.com/index.htmlDaotoad225 wrote:
does anyone here know much about the "secondary butterfly valves" I think this is what nissan calls the scv, or swirl control valve ??? I have read about removal, but it seems that it is a performance enhancing feature of the engine? help me out folks!
I dont think that he was putting down that much power either. Last i heard the guy who built it was trying to sell it. Yes the injectors are under the intake and if you look close it has custom flanges on each runner for and direct port nitrous system. I got the pic of that singel cam a few months ago....i cant remember where i got it.deviousKA wrote:Damn, nelson, who owns that sohc? If possible, let them know I would like to meet/talk with them, and would be interested in offering them some very good deals/sponsorship of some sort. Not to common to see these setups in S-chassis.
Looks like they put some good thought into the design, the picture doesnt load completely but are the injectors mounted underneath the runners?
That is a devious trick
I doubt it is putting down 290 wheel, NA. If it was, it would running a lot faster than 13.2. With that sort of power on that NA 2.4l setup he could easily lay down low 12's or even 11's with good drivetrain configuration. I guess you mention wheel spin, though, interesting.
What NA tuning are they running BTW?
You ever see the induction setup I had on my old sohc? The engine was completely built, 10.5:1 compression ratio and sitting at 2502cc.
I still have it, dont really have anything to put it into yet though, need a tube chassis. I didnt get a good chance to tune it out in my 240sx, I was already getting 10-12 mpg and still lacking fuel. I designed my intake manifold wth staged sequential injection in mind, but with the fuel prices going up and up and lack of cash to spend on too many "secondary cars", I sold the chassis.
And 240sx are heavy *** cars anyways, imho.
