240marcuSX »
https://forums.nicoclub.com/240marcusx-u5199.html
Wed Dec 22, 2004 10:03 am
it sounds like you know quite a bit to start off with.
timing adjustment - search for that here, theres a thread somewhere that talks about how much is safe and whatnot, advance for n/a, retard for boost, run higher octanes for either N/A or boost.
- no need for the walbro on a N/a, but will need one later
- headers and exhaust, kind of a waste of money if youre going to turbo a little while down the road, but if you must get them, get a hotshot header, brm exhausts are nice, but there are a bunch that are
- cams, youve got the 91' cams, so you have the nicest stock ones, but again, if you must, try jim wolf, or pdm.
- lsd, depends on what youre using it for, everything from vlsds to 2 way clutch types, more info please.
- clutch, clutchmasters, act, spec, centerforce, i cant really speak for any of the above except for clutchmasters, and mine is just fine.
oh and welcome to the club guy.use the search button,
