KA manual transmission question
op.tic
will an s14 ka24de 5spd transmission work with a ka24e?
excuse the stupid question but im not too familier with the ka
hbrown
Yes- they are all the same- SOHC, DOHC, and SR. I believe there starts to be some differences when you get to the S-15 engines though. All the KA's are the same though.
jramospma
Car: 240SX Coupe
hbrown wrote:Yes- they are all the same- SOHC, DOHC, and SR. I believe there starts to be some differences when you get to the S-15 engines though. All the KA's are the same though.
KA24X or SR20DET use same transmission ?
sil80drifter
Car: 1990 240SX Hatch
yes, but different bellhousings.
sil80
scruffy63
Car: my nissan 240sx
in other words the guts are the same but the housing is different.
jramospma
Car: 240SX Coupe
scruffy63 wrote:in other words the guts are the same but the housing is different.
OK thank´s
PhopsonNY
Car: 1989 Nissan 240SX
Does that mean that if you got a clutch and flywheel for an SR, it could be used in a KA24x?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
What he means is the guts are the same set up but due to different bell housings they won't bolt up (KA to SR) vice versa but the (KA24E to KA24DE) will, the splines on an SR are different. As far as an S15 the transmission is longer because it is a 6 speed which means the driveshaft is shorter.
Cooch
Car: white 1993 240sx
Now im guessing form what i just read that this will work...but i can take my 93 ka24de transmission and bolt it up to a 90 ka24e i am getting? reson being the clutch is bad on the e and my de is dead so that would make more sense to do that and not buy a new clutch
sil80drifter
Yes, there may be a wiring differenc of one wire, but the transmission will bolt up like it was meant to be.
sil80
Cooch
alright thanks
