KA MAF Cleaning Question
jamied311
Car: 91 Nissan 240SX Fastback
Ok... Last night I took my air filter and maf off of my car. When I put it back on this morning the engine started to sputter, which it never did before. Does it sound like the maf needs to be cleaned? And if so would I clean the stock KA MAF the same way as this one ? http://www.q45.org/maf.html
jamied311
ttt
180fan
Car: 89 fastback
clean it with a bunch of carb or brake cleaner. don't spray directly on the element, just let it flow into the holes where the mafs wire is located.
da40
Car: 1995 SE 240sx
k and n has a kit so u can clean the filters specially designed to clean the filters the right way only like 20 bucks
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
crc has a product called mass air flow cleaner. its a spray like carb cleaner, but a little less caustic chemicals. it dries with no residue and is made to clean all the kn oil and junk off the element. try a parts store.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
if you cant find the stuff srpowered240sx was talking about, just use brake cleaner. carb cleaner leaves an oily residue behind and will affect the MAF's operation.
srpowered240sx
word, the brake cleaner is better in substitution. btw, heres a link to an online retailer.http://www.midwayautosupply.co...19596
94 Q45
Hi, after reading the post I still don't know how to clean the MAF sensor, do I actually clean the filament(wire) on the MAF or the plastic piece around the MAF, and also do I spray on the filament directly or spray on the whole MAF sensor. Thank you for the explanation.
180fan
Car: 89 fastback
don't spray directly at it. It'll bust up the thin wire. Let the solvent flow over the sensor.
jes_96
Car: '03 350Z -- '96 240SX SE -- '02 Dodge Dakota QuadCab AWD
Ya .... what 'hector da 40' said.
I cleaned mine as described above last weekend with Gumout. Worked fine. Got rid of my little 'off idle' sputter.
