kouki munster »
https://forums.nicoclub.com/kouki-munster-u34314.html
Tue Jan 17, 2012 3:37 pm
Remember, turbos don't really do anything without loading the engine, so keep your right foot from pushing the loud pedal to hard and you will never make more than 1-2 psi. Also, a boost controller won't let you run less then what the waste gate is set to run, so just remove the boost controller and hook the waste gate directly to the boost source.(usually on the compressor housing or the hot pipe)
