SPIRONIUM »
https://forums.nicoclub.com/spironium-u36370.html
Sat Aug 04, 2007 5:30 pm
1992 240sx ka24de motor 165k miles all stock. Threw the car in 1st the other day to get around some rush hour stop-n-go traffic, the acceleration went limp without warning. Since then the car has felt like it has lost all of its torque. The engine runs very smoothly, nothing seems abnormal at all, at highway speeds in normal rpms it feels fine. But when i try to push it to accelerate theres just no power anymore. I can barely spin wheels in 1st if i drop it at 5000, and its just sluggish to accelerate overall in high and low rpms. Seems to rev a bit slower in nuetral as well.
I also had noticed that if i push it to just over 5500rpms the temp gauge starts to shoot up! I let off immediatly, and the temp goes right back to normal in an instant. I let the car cool down to check my coolant system, everything seemed ok, so i hit the road again to see if it was just a fluke. The temp gauge goes up everytime once i hit that magic mark of 5800rpms. What is this a sign of if anything?, could it be that the gauge is just not reading correctly, maybe its just getting some static or some wire is arcing at high rpms?
So far i have checked compression ~155 all across with one high cyl at 162
Vaccuum is healthy, i tested it because i had reason to believe that the cat was plugged up, (i went a bit crazy with the copper gasket spray while putting the OE exhaust + cat on ). Even though vaccuum was fine i still deleted the cat and put on a 3" straight through header back exhaust. I was assuming that the power would go back to normal and then some because the suspected clogged cat was gone, but unfortunately i only felt a slight difference, car is still sluggish.
I replaced the engine temp sensor (not the one for the gauge), new NGK plugs, air filter, fuel filter, double checked coolant system for bubbles.
Mafs is fine.
What should i do at this point? I need some guidance. Thanks
