240sxchick09 »
https://forums.nicoclub.com/240sxchick09-u141860.html
Thu Aug 27, 2009 9:10 pm
Hey, I just recently got a 92 240sx not too long ago, and it constantly overheats.. At first the lower radiator hose needed to be replaced so I did that.. Then, I changed out the T-stat.. Yes, with the valve at 12 o clock.Then the water pump.. Then one day it leaked all over the ground, so I searched for the leak, and it was the most complicated bypass hose ever known to man. If it wasn't for me having such small hands, I wouldn't have been able to change it without taking the thing next to the engine off.. Im a girl, so bear with me here.. All of these things and it STILL overheats.. Yes I bled the system.. I let the car running with the cap off for 20 minutes, and added more and more fluid to it until no more air pockets.. I test drove it, and at the top of my hill there is a light, i sat there n it slowly rose up to H.. I turned on the ac full blast and it slowly went back down.. I checked for necessary blown head symptoms such as, oil in the water, water leaking from exhaust and smoke.. Nothing.. HELP!!
