KA internals
Bussman240sx
Car: Nissan cars, and women
i am in the process of building up my KA24DE, i have found cams for it, however am not having any luck with pistons, rods and the valvetrain. any sites or stores would be a great help.
JJ240
Car: 95 white 240
I have a set of 10.5:1 pistons for sale, they arent forged. I do believe stock pistons are forged so no reason to replace them. Valvetrain I dont know about. Ive seen some nismo valvetrain stuff on a site before but I dont have the link handy.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock pistons are cast, not forged.
But they hold up well under boost, so most N/A apps will not *require* new pistons other than for a compression change.
And Bussman - You can use the SOHC pistons to get a static compression ratio of 11.1:1...off the shelf, OEM parts.
Later - Brian
Aries
Car: LT1 240SS
we use Arias pistons and rods in every motor we build.They hold up the best under extreme boost applications.
JJ240
Car: 95 white 240
This is the all motor section, I doubt he is trying to get his engine to hold boost.
Aries
Car: LT1 240SS
JJ240 wrote:This is the all motor section, I doubt he is trying to get his engine to hold boost.
boost, nitrous, high compression... Any situation that could result in detonation weather premature or as a result.
plastik240se
Car: 96 240sx se
ka24de.com has some stuff. dont know about quality though:)
CherryRed240
http://www.raceeng.com has some good stuff
