KA injector removal?
240fan
The cross point screws are tough but the vise grips helped. then how do you get the red plastic out, is that the part I need to clean? is it just held in with an O ring I broke one trying to remove it.
240fan
Oh, the Pop mechanics CD says I have to remove the fuel pressure, then the fuel lines and rail? damn...
Structure240sx
yes first relive fuel pressure, then take off those caps, u can use a flathead screwdriver under the plug to loosen it if thats not enough gently taek some pliers to it. there should be no need to remove the entire rail
TomsMR2
Car: cars.. etc
240fan wrote:Oh, the Pop mechanics CD says I have to remove the fuel pressure, then the fuel lines and rail? damn...
you can relieve quite a bit of pressure by removing the gas cap :)
pulling injectors is pretty easy. theres no trick, its very straight forward. id suggest pulling the fuel rail off totally tho.
