Nismo_Freak wrote:The rocker is loose and only about 1/6th of the weight of the rocker arm rests on the valve. The best cylinder heads ever to come out of Japan run rocker arms, keep that in mind.
My hypothesis on the rocker arm debate is that the HVLA's are incapable (read, not designed) to solve lash conditions at high RPM's. The lash then opens and the impact loading from the rocker and cam cause either the rocker to shatter, or for the rocker to dislodge.
Then again the KA's issue isn't the valvetrain design, it's the bottom end when it comes to sustaining high RPM. On the SR, you run into both a valvetrain and bottom end grey area when you are sustaining RPM above 8000 RPM. There are people running SR's to 9000 RPM on stock HVLA's, but I don't exactly want to put up with the mess when things go wrong. At those RPM's the OEM bearings and rod bolts aren't up to the task IMO.
That´s very true, most jap cars got rockers but only one got good reasons I think. Honda need it for the V-tec soo that´s ok with me.
The bad thing with rockers is not weight, reaction time or noise IMO.The problem is this, they brake. With every new moving part you put in an engine you increase the risk of problems.
Many high hp cars here have rocker problems, you buy stiffer springs and high lifting cams, the rocker brakes even easier after this.My friends SR20 got problems even after buying CNC made rockers.
Just hate rockers, if I can I would live a rocker free life.
/Mike
