Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Sat Jan 04, 2003 1:04 pm
As far as the turbo goes, the 3037 isnt a bad one, but of coure as the size of the housings go up, so does lag...its really what you have for goals and what you intend to mainly use the ride for...and what you tolerance for lag is. Another thing to consider is definatley your ECU. Jim Wolf can program you ECU for any rev limit, but be careful when deciding how high you will rev your car, this cas lead to catastrophic failure of a motor. If you rev to 8000, then a bigger turbo would be good for someone with maximum power in mind. But personally, i would like to have a car with 400 rwhp and a driveable power band. This is easily attained with the build up you sound determined to complete. As for the wastegate, the manifold MUST allow for an External wastegate, due to the GT series , I BELIEVE, not utilizing an internal wastegate. As for the injectors, definatly get bigger ones, but since the stock KA fuel rail can starve the last pistons of fuel, creating a lean situation in a hurry. What i would recommend is the msd 50 lb injectors and the JWT fuel rail. Its a bit pricey, so if you can get a machine shop to make one that is of good design...do that instead. AS for the boost level....20 lbs is totally achievable. With pistons rods, cam, head rebuild, a good wastegate, a GOOD ECU and fuel managent and efficient exhuast. 20 pounds will be no problem . And cool at that.
