Ka has no power?
whtrice
Car: 93 nissan 240sx
so i got a new ka cause i blew a hole in my old one the size of a soft ball. and my new one when driving has no power til it hits high revs then power pickes up. it never does it in the same rpm eather. anyone know anyhting or know of a thread that helps me out. thanks a bunch...help
gumby74
For starters, check all the obvious maintenance items. Plugs, wires, rotor, cap, ignition timing, fuel filter and any egr crap.Also remove the valve cover, and verify the mechanical timing is correct.Make sure the brakes are not binding. Start off with those things. Hopefully it is just something obvious and cheap.
whtrice
yeah iv tryed all that iv had the car for a mad long time and everything is working better than ever. its just the new motor dont run as strong as it should...
neverlift
vtec around 4000 rpm?
scruffy63
Car: my nissan 240sx
Don't patronize us with all your fancy vtec hoopla. Us nissan folk have variable timing.
Logan76
Car: Junk
Have you compression tested it yet?
