Postby
MOB240 »
https://forums.nicoclub.com/mob240-u46443.htmlSun Feb 11, 2007 6:45 pm
my question is: if i send the ka harness and rb harness in to wiring specialties, after the two are spliced together does everything just plug in w/no wiring whatsoever? thanks
Postby
USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.htmlSun Feb 11, 2007 7:19 pm
i can only assume that yes it will be plug and play. Only one connector comes back into the power/relay wiring. Grey or brown plug r/h wheel well goes to the fuse and relay box on the passengers side. This is a good option to go with and have it done professionally otherwise you won't be too happy with how the motor runs.
Postby
HxC_Nismo »
https://forums.nicoclub.com/hxc-nismo-u47634.htmlMon Feb 12, 2007 7:57 pm
shoot mckinney will do it for $400 bucks and its all plug and play. but i just got all my wiring info off of racebread.com and did my own wiring and everything worked perfect after i rewired my wipers with the ka harness.
Postby
HxC_Nismo »
https://forums.nicoclub.com/hxc-nismo-u47634.htmlWed Feb 14, 2007 5:31 am
heres the lower engine harness write up for the the 240sx it only took me about an hour to do its easy. http://racebread.com/files.htm and you can find the engine harness write up for the s13 and s14 on there too its not that hard if you know basic electricity. and it will save you the money and if you run into to any electrical problems you would know what to look for if you do it yourself. plus i think the s14 is easier then the s13 cause you only have the m63 plug to worry about just remember if you do you own wiring use the ka wiper harness cause the write up for the s14 the wipers will not work.
