Do you have the rest of your wiring done already and your engine won't start?S13 240SX wrote:do you mean ka black/red stripe wire to rb black/red because thats the way i have it and its not showing 12v's with the key to ON, none of them are wires are coming off from the oval plug show 12v for me.. and on my rb i dont have a solid red wire coming off the hanress plug where is used to wire and slice to the ka oval plug.
I just wired mine up like this over the weekend and it works great.CarlH Wiring Guide with my notes wrote:KA RB Black/Red > Black/Red (Thick wire)Red > White/Black (Thick wire)Black/Pink > Black/Pink (Thin wire) [Fuel pump relay signal]Black/Yellow > Black/White (Thick wire) [could not find on my RB harness]White/Red > White/Red (Thin wire) [This is the alt charge wire I think]Fusebox White > White/Purple (Thick wire) [constant +12v]Alt. White/Blue > Batt Terminal (Very Thick wire)
ok yeah that plug i checked every wire on it and none of them are 12 volts none of them give any reading what so ever.BoostFab wrote:
yes the black/red wire is hooked up... the white/purple is going to the fuse box white, my ecu lights and dash lighs come on, fuel pump comes on, i have spark, all the relays click when key is turned ON and back off.mello88 wrote:It's the black/red wire you're having trouble finding? Did you try hooking it to the KA black/red and try starting? Where did you hook the white/purple wire to?
Does it turn over? Do the lights on the ECU turn on when the key is turned on? Do your green relays click on? Fuel pump primes? Do you get fuel out the injs? Do you get spark?
I didn't measure for switched 12v on any of the wires. I just used the CarlH/skilzilla wiring guides, then figured out the white/purple wire (constant 12v).
Put up some more symptoms or answer my ??s above, we should be able to help u get it wired up...
well my battery is shows 11.60 volts and as for lower harness i'm using the ka lower and my alernator there's nothing special wired about it it all plugs in..BoostFab wrote:check the connection to your battery. which lower harness did you used ? how is your alternator wired ?
you my friend, are going in circle with this wiring. i need to clear you up, one thing: you are using the ka lower harness.S13 240SX wrote:mello where did you wire the ka black/yellow up to? black/white wire i found a few of them at my ecu plug? which pin does black/yellow go to?
do you have an aim s/n ?
Modified by S13 240SX at 10:37 AM 6/1/2008
no i'm not talking about the black/yellow power cable..BoostFab wrote:you my friend, are going in circle with this wiring. i need to clear you up, one thing: you are using the ka lower harness.
the thick black/yellow wire you are searching for is from the rb's lower harness. it's just the power cable on the lower rb harness. it 's in the engine bay by the fuse box.
you need to make sure you wire everything into the right place, look over all the write up, not just one. before hooking to the main power to the battery, as it can fry things if not wired correctly.
