Checkered-Member wrote:well if its free, pick it, and find out how different they are.
On a side note, There are some minor differences, the million dolor question is: are these difference small enough to have these engines interchangeable (direct swap)?
and how is this a KAT question?
I did pick it up. Its at my shop now. Tomorrow I will put it next to my spare block and check out the differences if any. I cant imagine that Nissan would cast two different blocks but would instead make bosses and mounts that could be used in either (all) applications. The Toyota 2JZ block is set up externally the same for NA v TT. Any block will bolt into IS300, MKIV Supra, GS300, SC300. There are bosses for positioning the motor mounts in different spots. But who knows, maybe Nissan doesnt do things this way.
I am sorry this isnt directly related to a turbo question. I have never posted in the KA (NON T) forum and didnt even think twice about posting here. I also think that members that are in this forum are probably more experienced then members of the NON T forum, although I might be making a bad assumption. Either way, this motor (if it works) will probably end up with a turbo slapped on it. Does that work?
