KA Engine Swap
Mystic X
:help
I was wondering of someone could answer a question for me. I need to know if it is possible to swap the KA24E from my 1990 240SX SE with a KA24DE from a 91 240SX, utilizing the existing transmission. And if so what modifications (if any) will be required. I hope someone has an answer for me.
Mystic X
240marcuSX
Car: E34 525i
E46 M3
well, if youre asking if a DE will fit in the 90' the answer is yes because its the same chassis, and you'll probably have to switch the power steering lines and reservoir just like you would with the sr20 swap,i dont know about the transmission, it might???? but why do you want to do all that work with a benefit of 5 hp? for the same amount of work and a bit more money you could swap an SR in and be done with it.
Infamous
maybe its a daily driver that needs a new engine, not everyones after brute power...:)
yashin
Car: football, rugby
15 hp not 5hp.... thats basic man
mattback
Car: being a big f'ng ricer
take a look at this
http://65.34.67.73/images/240/eric%20sohc-dohc/
use same trany
Nismo1182
Car: Z06
i just got done doing this swap a few days ago. everything is basically bolt on, except for the power steering.
240marcuSX
Car: E34 525i
E46 M3
oh my fault 15, sorry
but i wasnt harassing him i just wanted to know why all the work with little benefit.
how much do new KA motors cost anyway? ive never checked it out
UnderPressure
new? no i dea used like 400 bucks
MeaAnik
Car: car, shopping, working, adventure, design, art, blues, folk, alternative rock or country, eurobeats
yeah i'm interested too because it seems like used KA24DE engines are easier to find and with less miles on them
yashin
ive been told around 750- 1000 cdn dollars, dont know exactly what that coverts to though
sykoslider
Car: stuff
how about wiring the KA24DE into the KA24E? Is that all plug and play, or are there some connections I'll have to alter to adapt the DE harness to the SOHC cars?
jmancini
Car: 240's - duh!
Last year I swapped a 95 DOHC into my 90. No, it is not entirely plug-n-play, but its close!
Mechanically it all bolts up just fine - no problems. I believe all the transmissions are interchangeable between SOHC and DOHC, but I have no experience with an auto transmission. Here are the main differences:
Mechanical:Power steering - different between SOHC (pass. side) and DOHC (driver side). To swap, you need the DOHC power steering lines, reservoir, and hoses. OR, you can custom-build the PS lines. I did not try this but its probably not hard for an experienced shop.Intake - different shape, so can't swap that (you're gonna go aftermarket anyway, right!?)Throttle cable - SOHC too short to reach DOHC throttle body - can route it over the top of the DOHC engine, but best to get a DOHC cable.A/C is a different compressor entirely, though in about the same position. To make a DOHC compressor work with a SOHC system, you'll need to have a specialty shop custom fit the DOHC lines to your SOHC system. No, the DOHC lines do not just bolt to the firewall fittings, they are different sizes. Also, SOHC systems used R12 refrigerant, now illegal. You'll need to convert to R134, which means a system flush and new drier.Ignition - I understand the '91-'94(?) sytems use a different coil, but not entirely sure. The '95+ systems don't have an external coil, so not an issue there.
Electrical - SOHC systems and DOHC systems are somewhat different in the wire routing, primarily the power/fuse wiring for the ECU (at least for the '95 vs '90 systems), but also some sensors and inputs for the OBD, tach, speedo. It's not really a big deal if 1) you have the FSM (wiring diagrams) for both the SOHC and donor DOHC systems, and 2) you can read and understand the wiring diagrams. Then its a matter of identifying the differences, and cutting/splicing the DOHC harness to match the SOHC systems. The harness plugs that connect to the engine room and dashboard harnesses are different, so you have to cut to SOHC plugs and splice them into the DOHC harness. Takes a little time and you have to do it right, but like I said, not bad if you have a bit of understanding about how electrical systems work.
Also, you need a DOHC tach as the SOHC tach will not work.
Obviously you also need the DOHC computer.
You may have to change the transmission harness a bit to make it mate up, but that's minor (for the '95, I had to wire in the 2nd O2 sensor and crankshaft position sensor, no big deal).
That's about it in a nutshell.
BTW, I did the swap because my SOHC transmission was on its way out, and I found a DOHC with 41,000 miles on it...runs perfect, like a new car!
96sx
jmancini wrote:Last year I swapped a 95 DOHC into my 90. No, it is not entirely plug-n-play, but its close!
That is some good info...
RefriedNismo240
mattback,
are those pics that u posted in that link pics of a sohc transmission mated to a dohc engine? im trying to find out if they are interchangeable.
trpower7
Someone should make that a sticky, great info.
Philsnotfalling
Car: 90 hatch 93 coupe
old post I know but definately sticky worthy... atleast jmancini's info
crzycav86
Car: 93 Nissan 240SX KAT
Thanks for the bump.. it was a good read.
