ride4lame »
https://forums.nicoclub.com/ride4lame-u937.html
Tue May 11, 2004 4:02 pm
Okay, first off, i have a 1990 sohc that i plan to swap a 1995 KA24de into.From what I understand the 95 de has a second set of 'butterflys' in the intake manifold. From research I have done, i have found that it is better to eliminate the second butterflys. I am not sure why. My first question is, why is this better?Second, how do i go about doing this?
Also this is obviously an s14 motor, and i will be putting it into an s13, so i will need an s13de harness. Will this fit on the motor correctly. Which ecu should i use(95 or 91-93)?
thats about it
