KA-E to DE Help
WhiteBolivian
Car: '90 240sx
Alright so i'm new to the forum and to working on nissans, (but i've been reading a researching for a couple of months trying to figure things out.) i'm thinking about swapping out my E for a DE cause my E has about 200,000 on it. There are just a few questions that i can't find answers to, or i don't fully understand the answers that i have found. so here goes:1. Can i use my KAE transmission with the DE? (from what i've read i think i can, i'm just looking for a solid answer.)2. Will i need both E and DE wiring harnesses to do the swap?3. What if not all parts are interchangeable for the E to DE?(intake and exhaust manifolds, distributor cap, ect...) Any help would be great.
mach5camaross
Car: 90 240sx hatch KA24de-t
1. yes the transmission's are the same.
2. you will need the de harness and ecu for the de engine. remove SOHC engine, wire harness and ecu.
3. nothing on the e will interchange with thie de. try to find a complete take out from someone who swapped for an sr or somthing
WhiteBolivian
Car: '90 240sx
thanks mach5camaross, if i have any other questions i'll give you a shout.
PervyDrifter
Car: 93 fastback
i know the trannys are interchangable, but i heard that the sohc has shorter gears, is that true?
WhiteBolivian
Car: '90 240sx
ummm i don't know about that. i do know that my sohc does have short gears, but then again i don't about the dohc transmission. anybody have an answer?
PervyDrifter
Car: 93 fastback
I have a sohc too, and the gears are pretty short
lucky03602
Car: 96 d21 *work in progress*
01 xj Cherokee auto 4.0 4 1/2" lift 32x11.5x15 family dd
there is a great writeup on the swap
zerothread?id=162443
basically everything youll need to know is there.
honesly im doing the same exact swap as we speak but i have a complete donor car, and im also removing all emmissions and redoing the engine bay while engine is out so ill take a while.
do you have a donor car?? if not then MAKE SURE you get the power steering lines and resiviour from a 91-94 if you want power steering.
good luck bro!
WhiteBolivian
Car: '90 240sx
Thanks, i stumbled across this a couple of months ago when i was thinking about doing a swap and then i couldn't find it again.
