ka-e tick
NFixed85
Car: 1990 240sx
take the rocker/lifter out take some brake cleaner or carb cleaner. an use the straw to put it the hole where the oil would go into it. then take a pair of channel locks an squeeze the pad in till it gives or if its compress just use the clean and try to tap the rocker against something that will jar it lose. then try to bleed them i didnt have to use a needle or anything just soak it in a oil bath the press the pad it and release till it draws oil in an gets to where u cant move it. that about all i can think of
NFixed85
Car: 1990 240sx
This tick is getting really annoying, at a cold start my engine runs fine. However after the car gets to operating temp it starts ticking. I don't know if the car is getting to hot an the oil isn't working to well or a bad oil pump. Any ideas
zach-Ka
Car: 1990 240sx (SR)
How loud is it?
NFixed85
Car: 1990 240sx
load enough you can hear it from outside the engine bay and in the car. It sounds like a miss like the valve train isnt working right or something.I have plans to do a ka-de swap but im tight on money but i dont know which is worth fixen the single or swap over
zach-Ka
Well its more than likely your lifters. I would say just get a oil change and use a bit thicker oil, and start saving for the DE. You can probably find one on here for about $400.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
You have to bleed the lifters, and the noise will go away. Here's a how to that was written up by a member.
http://www.nicoclub.com/articles.php?id=215864
NFixed85
Car: 1990 240sx
well ive change the oil twice in one month the oil way i ever got it to stop before was put sea foam in the oil before an oil change but i had an idea of how to find the bad rocker arm unplug the coil take the valve cover off and locate the ticking rocker arm since the engine isnt spinning really fast at idle it wont fling oil every where.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
It's still going to be messy, idle is over 10 revs per second.
NFixed85
Car: 1990 240sx
well what do u think about the adjustable rocker arms that o and j performance makes or hybridka
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Bleeding the lifters is free. Plus if your going to be swapping it out for a DE, it would just be a waste of money. They are nice lifters, but I don't think that it would be the best way to spend some money.
Shifter
Car: 1989 240sx coupe
I'm having the same ticking problem,except my problem is that the 2 cylinders that make up the lifter are seized together.Anyone know how to get them apart?http://www.nicoclub.com/articles.php?id=215864This didn't really help
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
i would say go pull them at the local yard but i see your in alaska and that may make it a little tougher so if you cant find one there you can find one here http://www.courtesyparts.com/2....html
Shifter
NFixed85 wrote:well ive change the oil twice in one month the oil way i ever got it to stop before was put sea foam in the oil before an oil change but i had an idea of how to find the bad rocker arm unplug the coil take the valve cover off and locate the ticking rocker arm since the engine isnt spinning really fast at idle it wont fling oil every where.
An easier way to check which one is ticking is to take off the valve cover and push down on each rocker arm to see which one moves up and down. If they're working properly, they shouldn't move, but if they're seized/not bled, they'll have a lot of clearance between them and the cam, causing the tick.
