Posted this in the engine forums, figured it would do a little better over here. or i'm not bringing the entire thread over here i'll just post the link. so far it's got some random specs, rocker arm and rocker shaft. compression pressure. camshaft and camshaft bearing. and valves.
still gotta add piston ring, piston, crankshaft, bearing clearances, piston pins. and probably more if i can find any more tomorrow. and the specs for the DE motor. but that'll be a while. i need a damn scanner.
onto the actual thread:zer...specs
