locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Tue Apr 14, 2009 8:51 pm
how does it do when you give it gas? does it start to run normally when you open the throttle? if it does it shouldn't be the injectors.
check that egr valve make sure its not stuck open, its in the back on the passenger side of the engine, like the very back behind the engine at the top bolted up to the head (not on top of the head thats the bbt valve) the back. sometimes carbon build up will clog the valve and keep it stuck open causing it to make the car run horribly at idle when it should be closed at idle, put your finger up under the valve and try pushing the diaphragm open and closed. get a good feel on it, see if you can tell if something is obstructing it. remember even if it open just a little bit it will run bad.
you should take the valve off clean it up with a wire brush check the holes on the valve and the engine make sure there's nothing in there and slap it back on before buying new injectors.
also, Is your car throwing an engine light? if so you need to find out what code its throwing it could be related to your problem.
