D21_Destroyer wrote:sorry to not actually give you an answer. But I'd say check out
http://www.ka-t.org if you haven't already. they have threads dedicated to turboing each of these engines. And it's probably your best chance of finding people who've pushed either engine so you can see which has better turbo potential.
**** me, why even make a post in the first place? Did he or did he not say that he was building an NA motor? Open your eyes and read the OP's post before you post irrelevant bull****.
Chris, as i have mentioned before, you need to focus your efforts on the head, that is where you will make it or break it in terms of obtaining maximum VE's through out the whole rev range. Around where you want peak torque, you are aiming for 100% VE's and higher.
Your injector placement is going to need some trial and error to obtain a balance that you are happy with in terms of all out performance and idle quality. Whilst positioning the injectors to spray directly into top of the throttles at the trumpets is going to provide max intake cooling and atomization at WOT, idle quality and part throttle driveability are going to suffer. Just ask Gabe.
I'd suggest placing them immediately after the throttles, and try to find an injector that will have the best atomization for your given fuel rate requirement. At this stage, since i know what you are thinking, 370's would be ideal.
Be prepared to go through several iterations of headers based on your specific combination (dependant on cam timing for exhaust and exhaust port throat size); until you have those 2 parameters set in concrete, don't even think about building a header.
Your ITB manifold is going to require much thought, your main goal here is to get as much high pressure, cold air into the plenum as you possibly can to get intake velocity up. You will need to spend some time on the dyno to play around with different trumpet lengths, build your intake manifold and plenum to allow you to do this quickly.
