ka-e or ca18 injectors?
cornuts
Car: 91 nissan 240sx
ok my engine is stock with only walbro f/p, exhaust...but i was painting the valve cover, intake mani and the fuel rail so i found an injector that was leaking .. so i went to deatschwerks.com and seen that my injectors look nothing like the sohc injectors but look just like the ca18's so im kind of confused a bit would it be possible that they are ca18's or am i mistaking? so can anybody help a brotha out and post a picture of the differance between the two..
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
CA injectors are top feed 370s. they are also low imped and require a dropping resistor to lower the imped to run.......
you would need to modify your fuel rail to run them.
maybe SR 370s?
