KA-E N/A Project: California Smog
StumpPuller
Car: 1990 KA-e S13 FB, smashed while parked
1999 SR20 B13, Sold
1990 KA-e S13 FB, 10.6:1 N/A Project DD
Objective: Pass CA Smog with 10.6:1 Compression And Anything Else I Can Add, Looking For 170-ish HP, 190-ish Ft/Lb
Current State: 237k on the clock, all-but bone stock, currently passing CA emissions w/ flying colors
Dilemma: CA emissions testing requires Visual, Functional (Mostly Evap), and Butt-Sniffing to be legit. No Turbos, bummer. No Meth, bummer. No EGR/Evap delete, no CAT delete, nothing delete, bummer. Check Engine light on? Fail, period. It all boils down to internals, and C.A.R.B. approved Headers/Intake, etc.
Bonus! Neighbor wrecked his '89 w/ 110k on the clock, I got a free motor to eff around with :naughty:
New Block: Bored + Honed to 89.5mm, Decked to match T-cover, Arias 10.6:1/89.5mm pistons installed
Brainstorm 2013: Cosworth 90mm head gasket w/ T-cover delete? Are DOHC intake valves usable and/or worth it? No knock sensor w/ SOHC? Would probably fail NOx I would imagine w/ high compression, so custom-tuned DOHC ECU w/ Knock sensor?
I know, I know. Why N/A? Well, I'm not looking to see how long the legs are on a SOHC KA, it's pointless. But it did perk my ears when I literally pulled a stump out of my yard when a 4wd QX4 couldn't :facepalm:
So here I sit; venturing off of the beaten path of boost, entering the realm of feet and pounds over the power of horses for the sake of many hippies. And, so I can actually USE the power for a daily driver, and pass smog in hippie-ville.
Any of you barometric-level brainiacs care to chime?
Much appreciated!
Oh yeah, I would post pics but I don't know how. That knowledge would also be appreciated, haha.
Thanks! :biggrin:
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
your main walls you'll hit, 1-NOx. the early production had a harder problem with nox due to the slightly higher compression. and cali is steadily cutting the limit. iirc right now its at alittle over 700ppm. i can double check. 2-timing. part of that functional is the base timing. so youll have to run it at stock.
let me know how its goin. can answer all the smog Qs you have
Wc240
97 Nissan 200SX
06 Scion xB
the higher compression, may be worth lookin into improving the egr system slightly to ofset the nox production
