breadbox wrote:Don't do it. not worth it. DOHC blocks aren't that hard to find.
Well like I said I'm not asking for myself... The reason I ask is a friend of mine just had a motor built at a shop by a guy that built and races a 240sx in SCCA competition and he rebuilds his engine constantly for racing purposes. Well the motor he had built is a 10:1 compression with wiseco pistons and rods DOHC KA and lightweight flywheel/pully's and honed/balanced crank cometic metal head gasket ARP studs... the works. All the head work was redone also so everything is brand new and ready to go.
Well he was driving it (slowly for break in purposes) the last couple days and suddenly it started getting hot. He let it cool down completely and noticed it was low on coolant so the mechanic told him to bring it back by the shop and they'd do a leak/preassure test on the cooling system. He leftfor the shop and within a minute it started running hot again... He let it cool back to normal and started going again and didn't get a block down the road and it overheated again. He started it after it cooled with the coolant cap off and it blew up on him (blew all the compression through the radiator indicating blown head gasket) and he checked the oil and sure enough it was full of coolant all of a sudden.
How the hell do you blow a less that 2 day old cometic head gasket??? So I then realised that the guy that built the engine said he used a SOHC block instead of the DOHC block it had in it and when I aked him how the head could fit on the head he said it bolted right up. I just gave him an blank look like how the hell... Apparently he swapped blocks with an SOHC block he had lying around in the shop so he could have the DOHC block overbored to match his race car engine so he could have a backup engine that's legal in SCCA competition. He claims everything is the same and bolts up perfectly fine the only difference being where the pully's and knock sensor line up, etc. So we are thinking that maybe a coolant port for the block doens't line up with the head properly and that's why it blew the gasket. He hasn't gone above 25% throttle or over 3k rpm since he got it yet. This just doesn't make sense... How do you blow a cometic metal head gasket in less than 200 miles of it being installed if everything lines up right??
